3D printing service South Africa
FDM 3D Printing service in South Africa
SLS 3D Printing service in South Africa
MJF 3D Printing service in South Africa
SLA 3D Printing service in South Africa
Over 198 customers are satisfied with our 3D printing service.
“Very fast turnaround. Great print quality.”
Tyler, Roodepoort
“Very efficient in both responding to orders and printing.”
Marcello, Johannesburg
“Absolutely perfect, came out just right. ”
Julian, Johannesburg
“Excellent service! And quick turn around time!”
Shayne, Johannesburg
“Great service, timely responses, good quality prints and amenable to additional request to make a project come together without hassle ”
Chris, Johannesburg
“Awesome service as usual. Thank you Jason”
Hendo, Pretoria
“Great servece, great print quality, awesome reaction time. Just all round a great experience.”
Adolph, Cape Town
“Even with some of the lifting issues of my design, the print came out perfectly. Great to deal with and super communication.”
Raymond, Cape Town
Standard PETG, FDM
“Thank you for your prompt response and all-round great service!”
FJ, Cape Town
“Quality is good, service and communication are good.”
DANIEL, DUBAI
Standard resin, SLA/DLP
“Amazing service and will continue using it.”
Mishal
“Perfect print, great communication, fast delivery”
Ahmed, Abu Dhabi
“Very good quality, happy to deal with them, i recommend them for any one who need 3d printing”
Islam, Doha
“I had a tight deadline and they supported me and delivered ahead of schedule. Happy with the result ”
Martin, Dubai
“Amazing company. Fast work, friendly personnel, best prices, impressive quality. ”
Pavel, Dubai
“Great service! Everything came out nicely. Thanks!”
Vojislav, Dubai
Standard PETG, FDM
“Great job, quick service, will use again. Very happy”
Cody, Dubai
“Super professional. And good-looking too.”
ERAN, Tel Aviv
“Great supplier, and the level of service makes me return and seek him out whenever I need something printed.”
Pasha, Petah-Tikva
“Excellent service, very professional and helpful. Thanks a lot!”
Lior, Herzliya
“Great service and transparency with regards to operations and product delivery with great quality print to boot. ”
Morne, Sharjah
“The serivce was outstanding and I would recommend it!”
ABDULRAHMAN, Kuwait City
“excellent work. they are very cooperative. i will use their services again.”
Yanir, Timrat
Standard Nylon, SLS
“lightning-fast and super friendly. 10/10, will print again.”
Andre, Kiryat Yam
“Outstanding job! Will order again next time.”
Manjulal, Trivandrum
