3D printing service UK
FDM 3D Printing service in UK
SLS 3D Printing service in UK
MJF 3D Printing service in UK
SLA 3D Printing service in UK
Over 303 customers are satisfied with our 3D printing service.
“Couldn't be happier, service and quality is brilliant.”
Steven, Crewe
“Absolutely spot on! Will be using this again! ”
Martyn, Stoke-on-Trent
“This is my second order from this company and everything could not have been easier, communications were fast and the finished product was spot on. Will not hesitate to use them again.”
Andrew, Northwich
“Really good quality print Item arrived the day that was estimated Quick response time and really helpful/flexible”
Sam, stoke on trent
“Speedy service, valuable advice. Excellent communication. highly recommended!”
Ahmed, Manchester
“On time, design as expected. Many thanks!”
Reece, Manchester
“Great help and solved issues fast and effect. A+”
Christopher, Stoke-On-Trent
Standard resin, SLA/DLP
“Very responsive and helpful, would highly recommend.”
Tom, Salford
“Great print and very speedy production and delivery.”
Andrew, Warrington
“Very helpful and friendly service would happily use this service provider again.”
Tom, Manchester
Standard Nylon, FDM
“Thank you for the super quick service and response. ”
constandino, Manchester
Standard PETG, FDM
“The piece was perfect, exactly as I expected”
Javier, Stockport
“Really quick service and I'm really pleased with the result. ”
Matthew, Stockport
“Excellent service and delivery even down to the care taken with the packaging. This was the first time I have used the network and I would highly recommend.”
John, Newton Le Willows
“Good printer, well packaged, quick delivery. Recommended.”
Kevin, Oldham
“Thanks for an excellent service Felix! Very happy :)”
Jim, Dukinfield
“Excellent service & communication. Parts quality even better than expected as well :) Couldn't be happier with the service I received :)”
Graham, Bury
Standard TPU, FDM
“Brilliant . Many thanks Will share this with the Pebble community”
robert, STALYBRIDGE
Standard TPU, FDM
“Spot on service, really happy with the results”
Danny, Oldham
“Again fantastic service and brilliant communication ”
Kyle, Bolton
“Very good experience. Excellent service, would certainly use again. very pleased”
Lee, Priorslee, Telford
Standard PETG, FDM
“Great service, print quality and communication. Will be ordering again. ”
Mark, Oldham
“The print was great quality and it shipped quickly, thanks!”
Ben, Bury
“Quality of the parts was great, good communication and prompt service. Would definitely use again for any future needs”
Jason, Wigan
“I have no prior experience with 3D printed objects, but as far as I can tell this is a very clean print. The plastic is nice and flexible so it's not likely to snap under general use.”
Dylan, Wigan
