3D printing service United States
FDM 3D Printing service in United States
SLS 3D Printing service in United States
MJF 3D Printing service in United States
SLA 3D Printing service in United States
Over 206 customers are satisfied with our 3D printing service.
“We purchased a technical dimensional critical part with some special post-processing instructions and quality instructions. The vendor produced the project as instructed, and provided expedited delivery as well. We will place this vendor in our favorites listing for future use.”
Philip, Smithton
“Product was produced with great quality, speedy delivery, and commendable communication. Looking forward to using this Hub again!”
joe, Saint Louis
“From top to bottom, I'm as pleased as could be.”
JJ, Saint Louis
“Really really nice print and person!! Would definitely come again for more projects and recommend peers to come. ”
Phoenix, St Louis
“Everything met or exceeded my expectations.”
Kyle, Manchester
“Part turned out perfectly. Very happy with it. Quick responses to queries.”
Keith, Manchester
“First time ever using this service. Fantastic job. Thank you so much!”
elvia, creve coeur
“Rocket fast turnaround! Super pleased and will use them again.”
Michael, Alton
“Everything looks great! Already using the mount and it works perfectly. Extremely fast turnaround time with a great price.”
Scott, St Peters
“Awesome shopping experience. I will return with future projects.”
Thomas, O Fallon
Standard PETG, FDM
“Awesome communication and quality print job!”
Kyle, Lake Saint Louis
“Very Nice, a little bit off on measurements but easily fixed”
Sebastian, Winfield
“Parts were Outstanding! Every single one of them. Thanks for the assist getting my Prusa i3 Mk2.5 upgrade finished!”
Thomas Land, Troy
Standard PETG, FDM
“Professional service and great product, we will be back. Thanks!”
Sara, Rolla
“Pieces came out just as I'd hoped. Quick turnaround time, too. ”
Thaddeus, Bloomington
Metalfill PLA, FDM
“Quality printing, quick, and great communication”
Christian, Champaign
“Wonderful service and extremely convenient. The staff were very helpful.”
Logan, Urbana
“Quality prints and fast service and offered feedback on how I can create better prints in the future.”
Brian, Memphis
“Easy to communicate with and appears to take the job seriously. I'll likely be back for future prints when the need arises.”
Corey, Ozark
“I got my prints by the given date. They look good. Thanks! ”
Rich, Sterling
Castable resin, SLA/DLP
“Extremely impressed with how the print turned out. Will definitely use again.”
Lance, Iowa City
“Great response time and worked with me for shipping ”
Joe, Bourbonnais
“Quick turnaround, good packaging, nice looking parts. ”
Joshua, North Liberty
“Good print quality and quick turn around time”
Alex, Shorewood
“Great service, I'm extremely happy with the quality of my models, and even more so with the time it took to get to me. Would no doubt order again in the future.”
Ryan, Mount Vernon
